Take a look at the right rocker panel. When I removed it, I found it to be worse than it appeared.
Took a little wire wheel work and body filler, but I was able to clean it all up and decided to go the lazy route and not worry about trying to match the paint. I like the way the black works down there.
Cleaned up some corrosion today
- RoyBatty
- courtenay
Re: Cleaned up some corrosion today
Agree- that look pretty good!
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Roy, I did the same with mine. Kinda looks like a shadow,and any dirt is noticable but I like the black as well.
- 124JOE
i removed my crome trim and found that the screws started the rust
at that point i decided i would use stainless steel screws for everything that needs screws
and i stoped the rust asap
Agreed. The black looks good! And 100% SS hardware for me too if available. It is worth it.
