I'm not sure where this should be posted.
Currently restoring a spider, and I don't trust the title .
The engine history for the model year my car should be , doesn't match.
I'm way into this car, without knowing positively the actual model year.
Is there a Vin decoder on the forum?
I need to do the same for the 500L I'm restoring also, if someone has an all Fiat VIN schedule.
I believe it's a 1970, but I bought it with a lost title. I have one now, but the seller had to guess the model year.
Newbee VIN plate question
Re: Newbee VIN plate question
Check this out, may be of assistance in decoding the actual year.
http://www.esportscarparts.com/Fiat/SpiderHistory.htm
- 124JOE
The last Spider Europa is made as Pininfarina needs assembly line space to produce the forthcoming 1987 Cadillac Allante in conjunction with General Motors
those damm GM guys killed it off
