Between 25mph and 35mph I am getting a high pitched loud whining sound - changes with road speed rather than engine speed. First thought it was a throw out bearing - but pushing in the clutch doesn't alway stop the noise and changing gear doesn't help. Sometimes will have the noise at 45-50mph - and it is higher pitched than at 30mph. Seems to be coming from the front of the car. Wheel bearing?
Thanks for your help
Loud noise while driving
- kbee00
- Your car is a: 1972 Spider
1980 Strada (crushed)
1982 Strada (parts for the 1980 then crushed)
1966 MGB (E-Prod race car - sold)
1968 MGB (Targa Newfoundland - totalled)
1979 Spider (current vintage restoration)
1972 Spider daily driver
Re: Loud noise while driving
wheel bearings usually rumble, but maybe you have one adjusted improperly or a brake dragging. Does the car pull?
- azruss
mark is right about the wheel bearing. only thing i can think of is if one of the wheel bearing are dry, you might get a whine out of it.
- kbee00
What is the best test to eliminate the throw out bearing?
As for the wheel bearing - other than doing the wobble test for looseness, any other visual method? I should just pull the wheel and see if the bearing is dry....
Doesn't pull and it brakes nice and straight.
I will try to record the sound and post it. Tomorrow or Sunday.
Thanks for the help people....
