Boy it doesn't end every day it's a new issue.
Can anyone recommend a source for the power window cable. Mine snapped on the passenger side.
Cable for power window
Re: Cable for power window
No one came forward with a source on this issue ,so just in case anyone out there needs one, I found the cable at Lowes,looks like a 1/16 cable they had many sizes available.It might be metric because the 1/16 looked slightly larger in diameter. Will try it out soon I hope it works.
- 124JOE
i have a door without a window and the CRANK goes round and round
without stops on it.
it appears to be looped
if its the same size i have one for you
but you need to find out
