hood liner for 84 fiat spider
Can't find a hood liner so I'm making my own from a roll of insulation i bought at Pep boys. It has foil on one side and black insulation on the other. I will also use for my floor insulation under my carpeting. Does the foil face out or in for the hood liner? Same question for the floor?
- 124JOE
Re: hood liner for 84 fiat spider
foil faces taward the heat
so down under the hood
and up on the floor
IMHO
and up on the floor
IMHO
do you mean foil out on the hood and foil down on the floor?
- 124JOE
i seen on here people have the foil out so it can be seen
mostly stick back protecto wrap is thin
and dynamat is a bit thicker
tape seams with foil tape
this way it will hold water
