Replaced the heater control valve this morning. How does anybody with hands bigger than mine do this? Still I guess it went better than I expected. It had been replaced before by po with the newer version so no pipe bending was needed. Would have been nearly impossible to do with seats in the car.
Now I need to have my memory refreshed. J's the heat on with the lever all the way back or pushrd forward? It's been stuck in the on position at the valve regardless of where I put the lever.
Heater control valve
- azruss
Re: Heater control valve
look at the triangle on the control. the pointy end is closed. should be just the opposite of the fresh air lever.
