Removing plastic strip
Does anyone know how to remove that plastic strip right next to the windshield wipers? I have that cowl off the car but I can't seem to be able to get at it. I see the three goo dobs or whatever holding that angle peice on. If I take that off, how do I get it back on? Can I even take it off?
Re: Removing plastic strip
Are you talking about the black plastic piece right above the wiper mechanisim?
If so, you'll see a couple of plastic screws that are usually covered in that black sticky goo. Those screw out, backing away from the vent cowels. The plasitc is in two pieces joined by a steel clip.
AHHHH, Thanks. I will look closter at that GOO stuff to find the screw you mentioned.
Be real careful working off those rubber screws. They are easily torn. I soaked all in armor all and then slowly worked them off. It is the craziest method I have ever seen to hold 2 simple pieces of plastic grating down. But hey that's why we love these cars. Quirky in places!
Double Thanks. Being well prepairred not to make mistakes is much better than the way I usually go about things.
