Using 300W radiant heater to cure VHT paint on Ex manifold heat shield. (Heater is also great for working under car in cold garage!) $20 @ http://www.amazon.com/Optimus-H-4110-9- ... B000GG8DTS
For paint cure, used 3-30 min. cycles, cool and rotate position of part between cycles. Hope it is better than curing on car! Definitely better than discussions with Wife about using oven!
Heat Curing VHT on Ex. manifold heat shield
- dantye
- Your car is a: all gone
Re: Heat Curing VHT on Ex. manifold heat shield
I cured my VHT painted wheels in the kitchen oven. (Don't tell the wife). The smell was ok, but it did linger for about a day..... made up some sort of excuse.
- dantye
After 48yrs., I really don't want to take any chance of having to hunt for a new Wife!RRoller123 wrote:I cured my VHT painted wheels in the kitchen oven. (Don't tell the wife). The smell was ok, but it did linger for about a day..... made up some sort of excuse.
- 124JOE
well they should be lineing up "with that car"
- dantye
The line is long enough, thanks. (But, should a longer line form, I'm no more of a Saint than Jimmy Carter!)124JOE wrote:well they should be lineing up "with that car"
- dantye
Update: After baking the VHT flameproof paint on the heat shield 2 or 3 times at different angles with the radiant heater, all of the fumes seemed to be baked off. Then I put it in the oven for 30 min. @ 475F - highest it would go. No fumes, no drips, and a hard, porcelain-like finish. (And happy Wife!) We will see how it holds up on the car. (But it's just finally getting COLD here!)
