removing fan switch
roy
removing fan switch
Post by roy »
Need some adivce, I can't remove the fan switch at the bottom of the rad. I've soaked it in penetrating lube with no luck. I'm afraid to apply to much pressure as I can see the housing bend on the rad. Any ideas on how best to free this up?
Re: removing fan switch
a sharp rap on the wrench is better than steady pressure
Kent124
Post by Kent124 »
What size wrench are you using? I don't have anything big enough to remove mine.
roy
Post by roy »
I've been tapping it with a hammer I'll try a little sharper blow. At this point i'm using a crescent wrench.
Fiat88
Post by Fiat88 »
I used a plumbers wrench to get mine out. Mine was easy to remove, though.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
as mark said, do not twist as this will usually result in you twisting the bung out of the radiator. use a cressent wrench and smack it with a hammer, then it will come out, it is not to be installed very tight, just snug enough to seat the crush washer
75 spider
son has 78 spider
RRoller123
Post by RRoller123 »
Rarely mentioned is that when you apply penetrating oil, the junction should be tapped lightly with a hammer. The slight shock actually causes the oil to penetrate down into the threaded joint. It seems loopy but it really makes a difference. Squirt it on, tap it a few times, sharply, wait a minute, and it will perform better.
Pete
carl
Post by carl »
If the above ideas fail, bite the bullet, remove the radiator, get the right size socket and hit it with an impact gun.
carl
