Removing a Door Panel
- SeldomSeen
- Your car is a: 2018 Fiat 124 Spider
I have to replace the window regulator on the driver side of my '69 124 spider. How do you remove the door panel once the window and door cranks are removed? Anything I need to look out for?
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
1966 MGB Roadster
2007 MINI Cooper S
- MrWampus
- Your car is a: 1981 Spider
Re: Removing a Door Panel
You have to remove the arm rest and then just remove the screws around the bottom edge. It comes off easily so if it seems stuck in the middle, you still have a screw in it somewhere.
1981 Spider "The Mistress"
http://s1088.photobucket.com/albums/i329/mrwampus1/
"Because a 30-year-old sports car is cheaper than a 30-year-old blonde."
- azruss
once the arm rest is removed (3 screws) then you can have hidden clips around the outside. this will just pull out with a quick pull of the edge of the panel. the entire panel hooks to the top of the door, so just has to be lifted to remove. make sure you replace the plastic covering the door holes. This is a moisture barrier so your inside panels wont warp.
- SeldomSeen
Thanks. Not quite as easy as my MGB but sounds like no problem.
1966 MGB Roadster
2007 MINI Cooper S
1966 MGB Roadster
2007 MINI Cooper S
- 124JOE
my door panels are and was held on with philips head screws
3 screws for the arm rest
one standered screw on the door handle
and a hidden clip under the window handle
also it hooks along the top edge
Is there any trick to getting the clip under the window handle off? My arm rests and door panels are coming off this Winter for a full door cosmetic refurb. Have never taken apart one of these doors. Pete.
- 124JOE
i take a coat hangger and cut it to 10 inches
put a 90 bend at the end then cut it real short so 2 or 3 mm is sticking out
the other end needs to be a handle so bend it about 3 inches same direction as the first bend
slide the small hook under the back rear side of window handle to hook the clip and pull then pull the handle straight out
just dont loose the clip
then put the clip back on the handle
roll down the other window to see where the handle stops
having the first window down, match the position of handle and push it on in place
There is a tool that you can use to remove the horse-shoe clip that wont damage the window crank shroud.
Cheap, quick and veeery effective.
http://www.monstermarketplace.com/locks ... moval-tool
So the clip is a standard "Circlip" or "C" clip. Excellent info from you both. Thanks. Pete.
- SeldomSeen
thanks much all. I will get the tool too.
1966 MGB Roadster
2007 MINI Cooper S
1966 MGB Roadster
2007 MINI Cooper S
That tool is probably the best 8 bucks I ever spent (well there was that theatre ticket with the blonde back in HS, but I digress) it came in today and works like a charm. Had both door panels completely off in about 5-10 minutes. Highly recommended addition to the tool box.
No probs
Good work with the follow up post too.
