Fuel tank seal
Fuel tank seal
I have removed my fuel tank to cleán up some corrosion and need to replace the gasket that goes under the flange, between the tank and the trunk floor. Any suggestions on replacement material?
- 124JOE
Re: Fuel tank seal
just did this one mine
i used a window seal
a closed cell sticky foam
Re: Fuel tank seal
I was considering that approach. I also was sneering about plumber's putty.
Re: Fuel tank seal
I used window seal as well
- Your car is a: 1980 FI Spider
Re: Fuel tank seal
1980 FI Spider
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: Fuel tank seal
roof tar, window caulk, weatherstrip, W.H.Y. thats laying around the house and is cheap
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Re: Fuel tank seal
I'd be worried about that stuff holding up to fuel. I found this site that sells all sorts of gasket material and only Fluoro-
elastomer and Nitrile seem so be safe for gasoline.
http://www.allstategasket.com/info_specs_01.asp
under: Gasket specifications guide, select chemical resistance.
http://www.allstategasket.com/chem_res_cht.asp
Trey
- boogiedude
- Your car is a: 1978 spider 1800
Re: Fuel tank seal
This seal only seals the outside of the tank, and the body of the car to keep fumes and such out. It doesnt contact gasoline unless you've got a leak in the tank or line back there. And thats a whole other can of wormshtchevyii wrote:I'd be worried about that stuff holding up to fuel. I found this site that sells all sorts of gasket material and only Fluoro-
- DocGraphics
- Your car is a: 1978 124 spider
Re: Fuel tank seal
I used 3/8" X 3/4" rubber foam weather stripping from ace. Figuring if need be it would hold up to any spilled gas.
Looks mainly to be there to seal out water & fumes from the trunk.
The stuff there from the factory was just a foam gasket from what I can tell from what I removed.
Don Raugust
1978 Fiat 124 Spider "Fiona" - Burgundy/Tan
2011 pics: http://s918.photobucket.com/albums/ad22 ... 0Pictures/
2012 pics: http://s918.photobucket.com/albums/ad22 ... cs%202012/
- 124JOE
Re: Fuel tank seal
yes they used a foam
i wouldnt glue it in with any caulk or puddy
just be sure the flanges are flat and straight
my forward section was bent down now its not
and its sealed
and its sealed
Re: Fuel tank seal
Thanks for the replys. Now if I can just get the tank back from getting it sand blasted.
- manoa matt
Re: Fuel tank seal
"Now if I can just get the tank back from getting it sand blasted."
I hope they only blasted the outside of the tank and capped all holes/ports. The tank has internal baffles and the sand will be extremely hard to get it all out. Not sure how they would even sand blast the inside anyway. Most tanks are boiled out at a radiator shop.
