I collect up the tools and head over in the early am to his house for the fairly easy swap out. Then (you knew it was coming) one thing leads to another we spend ~8 hrs addressing everything in addition to the heater core. You know, re-wire the PO tangle left under the dash, eliminate the aligator clip in the trunk to the battery that powers the aftermarket radio, bleed the brakes, clean up the heater box and put on all new weather stripping on the sealing surfaces, flush the brown sludge excuse for coolant, re-wire the radiator fan, etc, etc, etc.
Finally, as it's getting dark we get aroung to actually hooking up the heater core and filling and burping the system. Added a flush connect in the heater return "loop" hose which I absolutely have to add to Luigi! Letting it warm up when I remember to check the passenger footwell and sure enough it's slowly filling with a green puddle
BTW, his current heater valve appears to be the original, thermostaic probe and control and all. Are they re-buildable? I'll put in a replacement on / off but it would be neat to have a working original.
