Brake flare fittings
I am installing new hard lines this weekend. Question....with all the trouble with flares seizing and not coming back off easy...should I put some antiseaze on the flare threads? This copper based brake tubing I got from Vicks looks like an easy job for Saturday.
- 124JOE
Re: Brake flare fittings
good luck
yes use it on the threads
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
+1 !!!
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Thanks!
This job looks like a slam dunk. I don't have a compensator so I am going directly from the master cylinder to the braided flexline before the T. Once I complete this job, I can say that just about everything in the front suspension, steering all shocks and the entire brake system is new. WHEW!!!
