But can you use a specialty insurer when you plan to drive the car more than on specialty times (to meets, shows, parades, etc?) I mean, I suppose you could always get the specialty insurance then drive as much as you want, but in case of problems, will the insurance co. still come through for you if you were, um, er.... just out running the engine to keep it in shape - ahem! ?Red, are you dealing with a specalty collector car insurance company, like Haggarty or Taylor?
Collector car insurance is cheap and good, and they know our cars.
If you are dealing with your conventional insurance company You will be paying way too much.
Also, would odometer readings factor into the issue? Are you limited as to annual mileage by the specialty car insurers?
Bottom line: what would be best for a Fiat Spider that is going to be driven regularly, but not necessarily as a primary car, in NY state? Because otherwise, NY state will be painful, for standard insurance. Very painful.
