Wyoming 1979 Spider
Wyoming 1979 Spider
New to the site but have found it to very informative. I have a 1979 Fiat Spider 2000. It is rough right now but in the process of getting it to run well. I could use all the advise that I can get. Thanks
Re: Wyoming 1979 Spider
Wow, another spider owner from the cowboy state
Show us some pictures and tell us how we can help.
I'm in Evanston and I know summer is going to be over shortly, so I am trying to get the spider run well quickly while I have time to drive it. I could really use some help with were all the vacuum lines hook up to the carb and other areas. Can some of these lines be plugged since we don't have to worry about emissions.
The best thing you can do for this is year is swap out the carb for a EMPI 32/36 from Allison's automotive. Then you can plug or remove most of that emissions junk and your car will run amazingly well.mountainspider wrote:I'm in Evanston and I know summer is going to be over shortly, so I am trying to get the spider run well quickly while I have time to drive it. I could really use some help with were all the vacuum lines hook up to the carb and other areas. Can some of these lines be plugged since we don't have to worry about emissions.
If you are in Evanston, then you might want to know about the UT Spider group...
Check out: http://www.fiatspider.com/f08/viewtopic.php?f=31&t=9375
Good people.
Good people.
Thanks for the props PC124.
Feel free to join the group. We all know Evanston is just an extension of Utah
If I can get mine on the road soon I would like to take a run through Evanston, pick up some goods
and back through the Uintahs home.
