Lower Grille Installation
luis1515
Post by luis1515 »
I just received a lower grill purchased here at the forum and noticed
it is different from the one I had installed.
What is the correct way to install it, has no screws.
Can somebody help me on this.
Thanks in advance.
azygoustoyou
Re: Lower Grille Installation
Post by azygoustoyou »
Do you have these parts? You need two of the clips (pink) and two of the clamps.
The clamps go onto the grill and fastens to the clips which slide over the metal behind the holes on each side of the opening.
Screws are sheet metal screws. :P
luis1515
Post by luis1515 »
Thanks for the information.
Will you sell them to me?
Luis
Fiat88
Post by Fiat88 »
Ah so thats how u mount it! Thanks for posting pics Brady. Will also have to find a set of mounting hardware.
azygoustoyou
Just make sure you have the clamp on right. It can only go one way.
I have at least one set of the metal brackets, maybe more, and numerous pink clamps if anyone needs them. matt.scarton@gmail.com
