Page 1 of 1
Brake Splash Guard Removal
Posted: Mon Aug 15, 2011 9:44 am
by jimmycakes401
I'm not sure if I'm calling it the wrong part, but I can't find it in search. I removed every part of the rear brakes including splash guards. I then sandblasted/painted everything and put it back together. I'm working on the front, but the splash guard has strange cut off bolts and look really hard to remove. I'm thinking I may just leave these. Any thoughts?
Re: Brake Splash Guard Removal
Posted: Mon Aug 15, 2011 11:23 am
by azygoustoyou
They are called dust covers. Those bolts are cut to fit in the small space to hold the dust covers on and everything together. I ruined a dust cover trying to get them off. I took everything apart and media blasted it too. You can get them apart. I think I used a large screw driver and pried against the head to hold them. Just be careful not to ruin the dust cover.
They are impossible to find.
Posted: Mon Aug 15, 2011 11:34 am
by jimmycakes401
They are in OKAY shape. I may just leave the front ones.
Posted: Mon Aug 15, 2011 11:47 am
by 124JOE
dont those cut bolts have nuts on the back side?
Posted: Mon Aug 15, 2011 12:44 pm
by azygoustoyou
Posted: Mon Aug 15, 2011 1:01 pm
by jimmycakes401
Hmmmm... guess that's not too bad. Didn't realize they had bolts on the back. I'm feeling pretty lazy right now. Mainly because I put some 80-90 grit media in place of my 70.... 70 was tearing it all off fast. Not so much with the new stuff.
Posted: Mon Aug 15, 2011 5:33 pm
by azygoustoyou
I took it all apart and painted it today.
The rain however didn't give me much time to finish all my pieces I wanted to get done.
I think I lost about 10lbs of media. I keep reusing the same stuff so it's not like I got my moneys worth.
I only use medium media. It breaks down and turns into fine. I just keep putting it in the tank.
Make sure you don't blast the steering knuckle shaft.
