Dual Weber IDF's for 1438
normark
Your car is a: 1969 124 Spider
Post by normark »
Is it worth installing dual Weber IDF's in my 1438, or is it just overkill? Got a 34 ADF today.
Of course nothing beats the feeling and the sound of dual Webers, but how will the car perform?
Daniel
Re: Dual Weber IDF's for 1438
Post by Daniel »
is the engine stock ?
normark
Post by normark »
The block is 1438 but the head is actually 1608. I'm not sure, but i think pistons, cams, and the rest are stock
124ADDHE
Your car is a: 1974 Spider Amalgamation with C40 Solex
Post by 124ADDHE »
Yes, the sounds and coolness factor alone will be well worth it plus the torque increase will make you..... :D
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
sptcoupe
Post by sptcoupe »
Dual 40s will work great on a 1438. Some of the very early BC european coupes came with 1438 engines and dual 40s fitted to them
fiat218
Post by fiat218 »
damn i want duals
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
bradartigue
Post by bradartigue »
normark wrote:Is it worth installing dual Weber IDF's in my 1438, or is it just overkill? Got a 34 ADF today.
It will work brilliantly if you can handle the initial frustrations of setting them up. I'd say a 34 ADF might be overkill, it delivers a lot more fuel per cylinder than a 40 IDF.
Daniel
Post by Daniel »
I May have a Dual IDF Manifold and carbs for Sale if you want them .
normark
Post by normark »
These were the answers I was looking for =)
Looks like the only downside (except initial set up) is that my wallet will be a little thinner than before.
But of course I'm interested if you got a spare set of manifold and carbs! Even though spider point sells a new set with manifold, cars and linkage, I rather buy used carbs if the price is right!
124ADDHE
Post by 124ADDHE »
Do it do it do it!
You also will get better fuel economy with these things if you choose...just another benefit.
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
bradartigue
normark wrote:Even though spider point sells a new set with manifold, cars and linkage, I rather buy used carbs if the price is right!
You'll do far better buying an original manifold off Ebay, then finding new or used carbs. These things are not rare.
You will not be able to use the big FIAT "turtleback" manifold with your hood, so don't bother with trying to buy one.
normark
Post by normark »
You mean the turtleback air filter, right? Something else that needs consideration, I mean will all manifolds etc. fit?
Daniel
Post by Daniel »
just use a ITG Filter !
normark
Post by normark »
Actually I've got a BS hood with the bumps. Will the turtleback fit then?
Redline
Your car is a: formerly a 1971 Fiat 124 BC Coupe
Post by Redline »
Just curious, how does the original big Fiat turtleback compare to a pair of "lunch box" filters for power and induction noise? My BC has the turtleback. I don't mind the look, or the current power, but to be honest it makes it a real PITA to check the oil.
http://www.124bc.com
