My car was out of commission for a few months while I was out of work. Been working again for a few months and just finished installing several items.
Car was working before with a intermittent start issue with the starter.
First of all replaced Voltage Regular. Because I was seeing 16-17 volts at Battery while charging. (That's why I burnt out some electronics and other batteries).
Secondly replaced starter with gear reduction starter. (the person who designed the starter mount is evil)
Lastly, the replaced the exhaust manifold header with chrome headers and a new down pipe.(Don't see how this is a issue)
Now The car turns over fine. The starter works, but the engine does not catch. I have 12.5 voltage at the coil.(and I had a brand new bosch coil already in my inventory, so I swapped it out.)
The ignition uses a fireball 3000 electronic ignition conversion. (No points).
Car turns over nicely. But does not catch. The car worked fine for the 4 years I had it before I replaced the starter.(I don't see how the compression could have changed during the starter install which is why I didn't test it).
I can't seem to get spark from a spark plug wire or the wire from the coil.
I am trying to get it fixed to go to the Big Larsz Tutto Itailano show Museum show in Boston this weekend?
Mark
--Fixed--Replaced Several Items car does not start
- 124JOE
Re: Replaced Several Items car does not start
yes i have an idea!
HELLO MARK,
i have a fireball 3000 i was having alot of issues.
bad ldle,staling,at times just no spark at all,
remove the cap inspect the three wires
on mine the grey one lost its covering right where it goes throu the
bottom of the dizzy.
find it tape it
check your timming
ask me how if needed.joe
HELLO MARK,
find it tape it
check your timming
I thought I only had two wires at the Dist side, but it turns out that I am going blind. I have 3 wires gong into the optical sensor.
How do you test these fireball units. I have the one that doesn't have a LED.
thanks
Mark
thanks
Mark
- 124JOE
three wire set up is ,black.white,greyit goes to the LED pickup under the cap
just remember where the shudder hat sits.mine moved aruond tomuch
ask me if you need to.joe
- 124JOE
hers some pics
top of unit IF MOUNTED ON PASS SIDE black then WHITE then GREY
Re: --Fixed--Replaced Several Items car does not start
Hey
I fixed the problem.
It turns out the control unit for the Fireball 3000 was fried. I got a new one from Amazon.com(at a great price) and installed the new control box using the existing optical sensor and the car started right up.
Thanks for the advice.
mark
mark
- DUCeditor
- Your car is a: 1977 FIAT 124 Sport Spider
- Contact:
Great news Mark!
-Don
-Don
