azygoustoyou: Thanks for the nice comment.
manoa matt: I was hoping the thermostat would not be noticed. I'm not sure how it got on there like that
I'm going to get some hose. I don't want too many strange smells or the wife won't want to ride with me. Then again... Nah, just kidding.
The oil leak was from the exhaust camshaft seal. It somehow worked loose. I tapped it back in, but who knows when or if it will work loose again.
I swapped the control arm bushings on Sunday and cut one coil off the front springs. The control arms are now parallel without occupants. I hope this isn't too low. The camber need some adjustment, but at least both look the same now. Now I have to cut the rear springs to get the rear down.
A little bit of transmission and brake work, and I'll have a reliable and safe spider. Then I can move on to interior work and paint
