Engine Stall
Engine Stall
I have a 1979 Fiat 124 that runs perfectly while the engine is relatively cool, but then stalls after about 5 minutes of driving as the engine heats up (when idling). Could this be caused from the hot air carb intake that is connected to the manifold, or is it something else (vapour lock or something). Thanks.
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
Re: Engine Stall
it would not be the hot air carb intake that is connected to the manifoldScott52 wrote:I have a 1979 Fiat 124 that runs perfectly while the engine is relatively cool, but then stalls after about 5 minutes of driving as the engine heats up (when idling). Could this be caused from the hot air carb intake that is connected to the manifold, or is it something else (vapour lock or something). Thanks.
Cheers David
see my >>You tube channel<<
