Abarth exhaust system
spidergirl
Post by spidergirl »
Hi there is an Abarth system for sale on this site but it is for either a 1400 or 1600 engine. Can any body tell me if it will also fit an 1800 engine as well.
Cheers Spidergirl
124spiderman
Your car is a: 1973 CS Spider
Re: Abarth exhaust system
Post by 124spiderman »
Hi
Are you refering to the rear muffler? It should fit with no problem.
As far as I can tell, there are virtually no differences from 1600cc to 1800cc engines cars in reference to chassis details.
The 2.0 had notable diffrences with refernce to exhaust mounts, rear axle/suspension and drivetrain. Also, engine sits slightly taller hence to larger bonnet (hood) bulges.
In any case, if its the rear muffler you are refering to - twin pipes -, Abarths had them as standard as they were 1800(CSA)
In the worst case scenario, any capable exhaust muffler guy can tweak to fit nicely.
Hope this helps
owned: 850, 124S/AC/BC/CC,128SL, 125S, 600D, X1/9, 2300, 131, 132, Uno, Punto
I own: 124CS, 500F, Bravo Sport T-Jet
I want to own: 8V, DINO SPIDER/COUPE, ANY ABARTH, '54 FIAT-TURBINA
kmead
Post by kmead »
If it starts at the exit from the manifold (the down pipe, two into one) you may need to make a spacer to bridge a possible gap from the bottom of the manifold to the top of the down pipe. There is a huge difference (A@1.5) on a 2.0 litre and I believe there is a smaller difference on a 1.8.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
Sunracer
Post by Sunracer »
Here is the answer, wee my post in this thread, I have one on my car:
http://fiatspider.com/f08/viewtopic.php?f=11&t=13840
