EL13 and LED turn signals. With PICS now!
whiterabbit
Post by whiterabbit »
Well kinda! I have always hated those butt ugly late model bumpers so Yesterday I snatched 'em off! Auto Zone and Lowes had all I needed. 1x1/8 alu strip and 1x1/8 steel strip I had on hand. 2 amber LED clearance/marker lights that were 1x2, single wire. 2 pieces of Alu bent into L shape 5x5 and steel strip cut long enough to go from the 2 studs from the rubber bushings that go around the frt bumper shocks. Leg of alu L get sandwiched behind steel plate centered in opening,light gets bolted onto other leg in center of oval with ground wire ran to ground lug in engine bay,pwr wire gets soldered with male butt connector that fits female plug on harness. Totally adjustable in, out, up, down to put the light where you want it.
550 is the standard blinker relay and those won't work because there's not enough load now(thermal). Triton EL13 (Auto Zone )is electronic and HD,round so it fits the holder,makes a nice "click" and works perfectly. Plus it made in the US! (little pricey but worth it)
Taped off the lens and gave 'em a shot of satin black. NICE! 8) Total cost=about $20 bucks.
I've read and read about this subject and all I can say is there's more than one way to skin a cat.
Gunsmith
Re: EL13 and LED turn signals. Too easy!
Post by Gunsmith »
So where are the pictures?
v6spider
Post by v6spider »
here here ya it's custom gotta see it.. :)
Rob
http://www.v6spider.com
TX82FIAT
Post by TX82FIAT »
yep.... gotta see the pics.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
whiterabbit
LOL! Let me read the FAQ's on how to post 'em. Promise to post 'em!
velozi
Post by velozi »
Without photos it never happened. Just a folk tale.
80yacht
Post by 80yacht »
So... any news on the pics?
whiterabbit
Image Hope it posts. LOL!
whiterabbit
Image Hmmmmm! :roll: Tadaaa!
whiterabbit
Image So... that's how it works. :lol: Just took a few months to figure out how to post pics! :roll:
whiterabbit
Re: EL13 and LED turn signals. With PICS now!
Thinking of cutting more screen and mounting them on the backside of it so it matches the other "brake rotor vents". So there! Pthhhhh! :P
124JOE
Post by 124JOE »
thanks for the pics.joe :D
Online
fiat218
Post by fiat218 »
original looks better
your welcome :)
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
east314
Post by east314 »
I am hopeful that you will post any modifications you make to your set up. Do you have any problems with mud or insect parts getting inside the "vents" when you take her out for a spin?
baltobernie
Post by baltobernie »
Clearance/marker lamps are not bright enough for turn signal applications. They are approximately one-tenth the required intensity. 25 is the maximum allowable candlepower for marker lights, and 250 is the minimum intensity for front amber turn signals.
Any misunderstanding between a Spider and a modern vehicle will have disastrous results for the Spider driver. If you're attempting to turn or overtake with those lamps on your car, be sure the sun isn't in you face. If it is, they other guy will never see your so-called signals.
