Steering U-joint-What kind of grease?
Fiat88
Post by Fiat88 »
I refinished/repainted the U-Joint which connects the steering column to the steering box input shaft. What kind of grease should be applied to it? Thanks.
baltobernie
Re: Steering U-joint-What kind of grease?
Post by baltobernie »
White Lithuanian
Those universal joints are sealed and any topical grease application will not help. The joints are staked into the yokes and non removeable. Another good reason to save that part on a parts car. A needle fitting on a grease gun may be able to get some grease in there.
kmead
Post by kmead »
baltobernie wrote:White Lithuanian
I know they are small but how do you expect a Lithuanian to hold onto the shaft as it turns round and round. May not have much room for your legs when you have one under there either.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
divace73
Post by divace73 »
LOL I was thinking the same thing about the poor Lithuanians
Cheers David
see my >>You tube channel<<
Fiat88
Post by Fiat88 »
manoa matt wrote:Those universal joints are sealed and any topical grease application will not help. The joints are staked into the yokes and non removeable. Another good reason to save that part on a parts car. A needle fitting on a grease gun may be able to get some grease in there.
Thanks for the heads up Matt. Glad I didn't try to clean the old grease out. :shock:
