Pictures
Re: Pictures
first you host your pictures in someplace like photobucket (http://photobucket.com)
Then you use what is called BB codes to put them here. [img] your picture url with no spaces here [/ing] (you will see the second [ ] I misspelled the code. it's img but if I had put that in the bracket you could not see what I had done since your computer would have tried to find the picture in my sentence.
Also... there is a size limit. 600 across, or the forum will chop it off on the right hand side.
Hope that helps.
Hope that helps.
- RoyBatty
Re: Pictures
After you upload your pics to a photo hosting site, click the "Img" button and place the web address of the desired full size image in between the img's
[img ]insert pictures web address here[/img]
