Brake fitting adapter
pooldoctorstl
Post by pooldoctorstl »
FYI.....Plews-Edelmann makes an adapter to use standard off the shelf 3/16" brake lines available at any auto parts store on our cars. Edelmann part #271330 and adapts to our 10-1.25mm fittings. Available at any parts store that can get Edelmann fittings, or I know O'rielly Auto Parts on the web and stocked in some stores. About $5 each.
If you are doing all of the brake lines on your car it is probably best to order a complete set from one of the vendors like Vick Auto or IAP, but for a quick fix or one line replacement they work great. I've used them with no problems.
Jeff
TulsaSpider
Re: Brake fitting adapter
Post by TulsaSpider »
Hmmmm good to know!
