Sent the car to the body shop in Oct 09
Started to dig around and found a bit of rust, ended up doing a lobotomy of sorts
Sliced a front end on from a 79 parts car I have
Spiced fenders on with the lower light parts supplied from a couple of members here
Getting a shape now
In primer now
Paint finally, have to do a wet sand. I don't know much if anything at all ,about painting,but Fred said this new PPG paint is water based or something and is not as good or does not lay down like the older stuff or the Dupont paint he uses now.
He put numerous coats on to cover and will wet sand the car.
I should have the car at the shop perhaps this weekend and then the fun stuff starts.. putting it all back together. I've spent the past few days trying to find it all.
Chris
72 getting closer to comming home
- courtenay
Re: 72 getting closer to comming home
That looks great, Chris. We're going to be in Oliver from May 31 to June 8. Hopefully we can get toghether at your shop so I can see this beauty up close and personal.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
That looks real sharp Chris. I hope you get it back by saturday so I can gawk at it a bit.
Zach
Zach
