Hi all.
Just a word of caution to all 124 owners. Check your car's crossmember bolts for tightness as mine had worked themselves loose.!
Apparently a common thing with the 124
CHECK YOUR CROSSMEMBER BOLTS FOR TIGHTNESS!
- 124spiderman
- Your car is a: 1973 CS Spider
owned: 850, 124S/AC/BC/CC,128SL, 125S, 600D, X1/9, 2300, 131, 132, Uno, Punto
I own: 124CS, 500F, Bravo Sport T-Jet
I want to own: 8V, DINO SPIDER/COUPE, ANY ABARTH, '54 FIAT-TURBINA
- TulsaSpider
Re: CHECK YOUR CROSSMEMBER BOLTS FOR TIGHTNESS!
Sage words. I found mine loose before, not good!!!!
Tightened mine up last year and then put another nut on as well to try and act as a lock of sorts. Two years ago the weld broke on one while tightening. Stick welded back up and good to go.
Chris
Chris
