Where can I get a chin spoiler for me 75/ Iv'e gone ahead and ripped off the bumpers and I'd like one to help with the look im going for.
Anthony
Chin spoilers?
- FiatMac
Re: Chin spoilers?
AutoRicambi has them. http://stores.auto-ricambi.net/Categories.bok
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
- FiatMac
Re: Chin spoilers?
It is in the on line store under Restoration/Exterior.
OOPs! Didn't notice that it says 1979 on. However, you might want to check with Casaba and Ramzi. I don't think the front end of the car is different between your '75 and the later cars, and it might fit the earlier cars.
Stan McConnell
83 parts car
83 parts car
- manoa matt
Re: Chin spoilers?
The chin spoilers were fitted to cars starting in 79, but can be installed and will fit on all model years. The originals were plastic, and I don't know if they were glass reinforced. Our Moderator SoCal Mark sells a reproduction chin spoiler made entirely of fiberglass which is much stronger than the plastic version (cheaper too). I've pulled too close to curbs, or parking stops on several occasions and herd a terrible noise only to find the spoiler un-cracked and good as ever.
When you install the chin spoiler go to the harware store in the weatherstipping section and get a roll of black 1/4" thick x 3/4" wide closed cell neoprene with the adhesive backing and stick it along the mounting flange on the spoiler. When mounted to the car it will close up any gaps between the sheet metal and provides a flexible connection so if you do scrape a curb the spoiler can flex and not transfer the force to the sheet metal causing it to bend.
Re: Chin spoilers?
awsome, thanks a ton for the heads up on the install. Any idea on price for the fiberglass ones?
- TulsaSpider
Re: Chin spoilers?
92.90. Nice tip about the flexible mount!
