rear brakes
rear brakes
81 spider.......found a brake fluid leak just over the rear track bar, pass side..looks like a preportion valve for the rear brakes...anybody done one of these...and where can I get one..any write ups..did a search, but no go.....L
- azruss
Re: rear brakes
had an extremely thorough discussion about this little do-hickey on Mirafiori within the last 6 months. bottom line is it can be bypassed without any serious side effects.
Re: rear brakes
Sweet, anybody done this with a writeup? I know I can figure it out, but the visual would be nice....thanks...L
- RoyBatty
Re: rear brakes
Best advise I can give is to thoroughly clean the area with a blast of water and a bristle brush to remove the accumulated grime before you start work in this area.
And when installing the new valve, connect the hydraulic lines FIRST, then go ahead and install the bolts that secure it to the bracket. Otherwise you risk cross threading the fittings. You'll understand it when you get there.
Good Luck
Good Luck
- TulsaSpider
Re: rear brakes
It's very simple. Mark Sells a bypass. You remove all the old junk and replace the bypass then bleed. Might as well replace the central brake hose too.
