Opinions for lowering.
kensmith
Post by kensmith »
I want to lower my 1978 Spider around 2" in the rear and 1" in the front. My thoughts are to cut the rear coils 2" and front 1". That should drop the rear maybe 2 1/2" and front 1 1/2" at most. Then take the car in for an alignment. Any suggestions or thoughts? I'm not doing it for racing or cornering, just to lower the stance. I will also replace the shocks at all 4 corners. I did notice the exhaust hangs kind of low, may have to figure that out? It's a Calif car with cat so need to be careful.
narfire
Re: Opinions for lowering.
Post by narfire »
Remember the car will sit lower yet with one in and even more with passenger as well.
Perhaps just try 1 coil rear and half front first,then put some weight in the car,go for a drive ect. and see what you think.
These are stock springs? Replace shocks with the KYB G-2's?
Chris
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
Here you go... grab an espresso, sit down, relax, and start reading :) :
Cutting the springs
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
kensmith
Post by kensmith »
wachuko wrote:Here you go... grab an espresso, sit down, relax, and start reading :) :
Cutting the springs
I had read that post and will read it again. I'm going to take some under car measurements with 2 people in the car before I do anything. Last thing I want to do is lower it too much and worry about speed bumps etc. Thanks
azygoustoyou
Post by azygoustoyou »
If you decide you cut too much off. I have two sets of stock springs at stock height just waiting for a home. Just PM me.
kensmith
Post by kensmith »
azygoustoyou wrote:If you decide you cut too much off. I have two sets of stock springs at stock height just waiting for a home. Just PM me.
Thanks!
