driveshaft removal
biil9
driveshaft removal
Post by biil9 »
good evening guys,
i am restoring a 69 spider and i am stripping it down and am trying to get the driveshaft out but this is not the norm for me and i can't figure out what trick their is to getting it out. anyone with prior experience i would appreciate any tips. the biggest problem i see is securing the driveshaft so i can undo the bolts and also do i have to take out the 3 bolts that are facing the back of the car? will it come out then or do all the bolts have to come out. thank you for any help.
barry north providence ri
TulsaSpider
Re: driveshaft removal
Post by TulsaSpider »
are you talking about just behind the transmission? yes you have to remove all the bolts.
bakercs
Your car is a: 69 Fiat 124 Spider
Post by bakercs »
I was a first timer at this not long ago.
Remove the bolts that attached the drive shaft to the differential. The drive shaft will still hang there, mine had a sticky coating between the face of the drive shaft and the differential. Put a short piece of 2x4 back there and gently wack it a couple of times with a hammer, that breaks the sticky. I had an appropriately sized cardboard box under the drive shaft to catch the back end. Pull gently on the drive shaft and it will remove itself from the back of the transmission.
'68 Fiat 850 Coupe & '78 Fiat Super Brava - Bought New
'74 Fiat 124 Spider - A While Back
'69 Fiat 124 Spider - Now
Carl
baker_cs@bellsouth.net
You are . . . What you do . . . When it counts
biil9
Post by biil9 »
thank you. it looks to me as though i have to take out the tranny support in order to get at all the bolts. does that soung right?
biil9
Post by biil9 »
it's out. thank you for your help guys. another day. another learning experience.
Odoyle
Post by Odoyle »
To clarify the procedure, you unbolt the driveshaft that connects to the rear axel/diff (its the 13mm nuts) and from there you can slide out the driveshaft? Or do you have to somehow remove the rear transmission mount near the donut spindle then pull the driveshaft.
