Pic of clutch pedal return spring needed please.
I need a good pic of the clutch pedal return spring and S shape helper please. My shop manual does not have a good pic and there seems to be many different types when I look at vendors springs. Also need to know where it attached at the pedal and if it attached at the same place as the brake pedal return spring. Thanks!
Re: Pic of clutch pedal return spring needed please.
?? Several people have already provided pics and link in your post just a couple down from this one.
Keith
Keith
I have mine apart. This is how the spring is suppose to be though.
Perfect, thank you very much. I will try and find the correct spring helper and attach the spring Matt gave me.
Let me know how it comes out. Mine is still apart. That sucker is very hard so be carefull
I will do the pennies between the spring coils method to stretch it, then after it's on, remove the pennies. Not sure why that spring needs to be as strong as it is.azygoustoyou wrote:Let me know how it comes out. Mine is still apart. That sucker is very hard so be carefull
