brake bleed question
81SPIDERMATT
Post by 81SPIDERMATT »
i know about supporting the rear axle i know the order my question is can i support and do the back to get out the possible air bubble in the mc then let down the back raise the front and then do them without a bubble moving around ????
azruss
Re: brake bleed question
Post by azruss »
once the air bubble is in the lines, how level car is doesnt change the bubble location. If you are worried about bleeding the MC, crack the brake lines at the mc first and pump until you get fluid out and then tighten them up. This is a little messy but with care, not a big problem. the only issue with the rear end is bleeding the brakes with the diffy dropped. this activates the compensator so you cant bleed the brakes. If the system is completely dry, fill up each caliper thru the bleeder hole. this will speed up the process.
81SPIDERMATT
ok i see..because the brake lines are on top of the mc... i understand...thanks so much...tired of pumping brakes to stop... going to find that bubble ... hopefully
