Can someone doublecheck my e-cable routing and exhaust hanging; failing to have any pictures and according to what drawings I could find, the e-cable passes under the resonator. I sorta remember this but wasn't sure if it's supposed to touch - I don't see any way for it not to.
Brake E-cable/exhaust routing
Re: Brake E-cable/exhaust routing
that is correct, you may want to wrap the cable at the exhaust pipe contact point
Like Mark says, that's the correct way. You should get at least 3 drives out of it before you find the cable sheath melted.
