On my 1979 carb spider the PO had an electric fuel pump instaled in back at the gas tank and it still had the mechanical pump on it also. I had a problem with the engine cutting out and I change the fuel filter at the carb and this did not solve the problem. I completely removed the electric pump, checked the filter in the tank ( looked to be clean
) and gas was clean. The car restarted fine and I drove it for about 40 miles on back roads and main highways in order to run at various speeds.
It seemed to run fine but now the fuel drains out of the filter at the carb overnight. Is this normal? Thanks for the help and advise.
George
