Brake Question
Brake Question
Having some brake problems on my 76 124 . Rear calipers. Should I replace the calipers or rebuild? What should I look for to make the decision after pulling the calipers ? I hope it's a rebuild. Thanks
Re: Brake Question
you can rebuild them, but the rears are a little tricky and the kits don't include the large boot to cover the e-brake arm
- TommyClocks
- Your car is a: 1975 124 Spider 1970 Corvette Roadster
Re: Brake Question
I agree with Mark, I replaced the rear calipers with rebuilt units. While I was at it, I replced the front calipers too. RockAuto.com has some decent prices and the brand they use is Cardone. I've had some good results with them. The car stops really straight now.
---Tommy
1975 124 Spider "Jeanie"
1979 X 1/9 "Natalie"
Re: Brake Question
Rebuild them if you want to, but it's easier to just replace them.
- seabeelt
- Patron 2019
Re: Brake Question
Look for pitting on the piston and inner surfaces. If they are corroded/pitted past the point of making a seal between the body and piston you need to get new ones, otherwise you leak fluid and have poor braking action. I would not compromise here. If there is any doubt - replace them.
Re: Brake Question
The rear calipers are APITA to put back together. Tony fought me every step of the way.
