Can I take the head assembly off without disassembling the valves assembly and the rest of the stuff,
do I need to drain the oil ?
manifold and exhaust are off already.
Danilo
head assembly?
Re: head assembly?
Yes, just pull the head bolts and your set to remove that head. U did drain down the radiator right?
Re: head assembly?
also unhook the exhaust or you will have to pull really hard to get that head out
- TulsaSpider
Re: head assembly?
And drain the block too! or it will be messy!
Re: head assembly?
... and don't forget the cabin heater supply pipe, which is cleverly attached to the exhaust manifold stud.
