Brake Problems
Brake Problems
Situation, my braking system can't hold pressure. Whenever I press on the brake pedal it goes half way and I hear a puff of air and lose pressure. I've replaced the master cylinder : no luck. Now I'm thinking the problem might be the Vaccum booster. Reason being is that I've rebuild all my brake calipers also. and replaced the hoses that go from the brake line to the brake caliper. Not leaks anywhere, and no pinches in the line. Help?
- manoa matt
bleeding rear brake lines
Chech out "International Auto Parts" at the top of the home page click on "Technical Bulletins" under Fiat go to brake system. Click on the first article it gives a picture of a rear brake compensator and describes the process of bleeding the rear brakes. Very informative
good luck
matt
good luck
matt
I agree with Mark -Keep bleeding the system, you've still got air in there somewhere. There is a procedure/order for doing it correctly, but it escapes me at the moment -maybe someone else will chime in. Doesn't sound like a booster to me..only other thought is that you may have a leak in the line, but I imagine you'd have seen that.
Marks right, you still have air in system. My 79 was a b----. Get someone to gently push brake pedal, crack open the lines at MC and bleed all lines at MC. I would gravity bleed the l/r then r/r,r/f, thenl/f. You probably will still have air, have someone help press brake pedal and re bleed. Ive seen other kinds of cars that were also very difficult. Its funny, my 79 is the only car ive ever been able to bleed the L/R by myself, if you stretch, you can reach it! Good Luck!
Wait a second....he said he hears a puff of air and it loses pressure. The first time I read this, I immediately interpretted this as the booster.
By "losing pressure" he probably means it stops braking as well (meaning you need to press harder).
I just found with mine that when I press the pedal and release it, depending on pedal position I get "puffs of air" as well. Mine is not so bad as to affect braking terribly though I do know it's a bit harder to brake. It's just a bit more like manual braking for me
I was actually wondering if there is a seal, or if the booster is totally shot.
Anyway, I just thought I had to interject since I'm pretty sure that is actually what he's talking about.
Chris
Chris
No luck and a cramped right leg. I went to auto-zone today to see what they had to say. He told me to start at the caliper closest to the master. And that I need to pressurize my master [or something to that effect] And last but not least man told me that I needed to have my car running for the booster system to bleed them. We've been only bleeding the back could my compensator valve be defective?
are you getting pressure when you bleed the rear calipers? If you're not getting much fluid, disconnect the link from the compensator to the axle. Push up and retain the link as high as it will go. That will allow full pressure to the rear brakes. If you don't do this, you'll never get the rear brakes bled.
