Water pipe pics
Water pipe pics
Can anyone post a good, clear pic of the water pipe installation? This is the pipe from the rear of the water pump that lays under the exhaust manifold. I cannot for the life of me see how the supporting bracket fits to the exhaust mounting stud - I think my bracket would have to be bent like a pretzel to attach and that can't be right. Thanks!
Re: Water pipe pics
Sorry,I don't have a pic handy,but I put a washer and nut on the stud first to mount the manifold. The pipes I've delt with seem to have a hook or open end and I can get that onto the stud and add another washer and nut to hold in place. If it is bent I'll use a long pry-bar and push the metal back into shape to it kinda sits on the stud. Yes a bit fiddly down there but it does fit with some persuasion.
Re: Water pipe pics
Sorry for the dirty engine, I didnt have time to clean it. Hope this helps.
Re: Water pipe pics
azygoustoyou wrote:you could have at least taken a wire brush to it.
Bawhahahahaha
Looks like a factory photo doesn't it?
Re: Water pipe pics
And you do very well!! Thanks for the pic - I can see now mine will need to be bent quite a bit. I just want to make sure I still get a good seal at the water pump end after I bend my bracket.
- DUCeditor
- Your car is a: 1977 FIAT 124 Sport Spider
- Contact:
Re: Water pipe pics
Here is a clear one one with diagramatics. But I've never seen one actually installed in a Spider. Is that commonly done in CA?
-nod
-nod
Re: Water pipe pics
I woke up on the wrong side of the bed this morning only to read this post. TOO FUNNY!!DUCeditor wrote:Here is a clear one one with diagramatics. But I've never seen one actually installed in a Spider. Is that commonly done in CA?
-nod
Thanks for making my day!
- DUCeditor
- Contact:
Water Pipe Installation Suggestion
I'm still not convinced this is a good idea, but when a forum member requests help we should all do what we can.
I particularly like the mods this owner made to his seats and center console.
-nod
-nod
