Evaluation of my header by Jeff Scheferman
here's the link to the FiatCenter thread;
http://fiatcenter.com/bbv2/bbBoard.cgi? ... gtid=11864
mdrburchette
Post by mdrburchette »
That's a great write up on your performance header, Mark. Did I mention they are also extremely sexy? :wink:
no, you hadn't mentioned it, but others have 8)
Spyderbuddy
Post by Spyderbuddy »
i'm sorry mark, i've forgotten what your sugestion was with your header and fuel injection. saw that with carbs it leaned the engine out but with the o2 sensor in the header will it lean out the fuel injection bad
Spyderbuddy
oh by the way love your headers and exhaust system just waiting on more money to get the system other things come first
On a FI system you would need to check fuel mixture through the rpm range. The O2 sensor doesn't affect the Fiat system at speed. The injector pulse rate is set by rpm and air volume.
I haven't installed a system on an FI car myself, so I haven't had the chance to test fuel mixture results. The AFM may have to be tweaked if the air bypass on the AFM isn't enough adjustment.
