Purchased the parts to convert it to the two way thermostat which is the way I've been recommended to do - and am wondering if I should take out the thermostat in the head?
Also wondering why my Haynes manual says that my present set-up is the way it should be on 1598 and 1755 engines (mine is 1755)
All ready to put the cooling parts back together after a new timing belt and water pump have been installed.
Thanks.
Here is a picture before I started
