Things done a year ago:
- replace plugs and wires
- replace cap and rotor button
- replace air filter
- took out gas tank and POR 15'd it!
- replace fuel filter
- replace fuel lines (ones attached to the gas tank/filter)
- replace fuel sending unit
- replace ignition switch (holy crap)
- broke into trunk, drill hole where liscense plate goes (missing key)
Stoppped working on it because would not run...bearly idled with thottle all the way down (really rough)
Things done last week
- got it started (yeah)
- rebuilt front calipers
- replace radiator cap
Things to be done with parts currently have:
- finish rebuilding rear calipers
- replace rotor and brake pads
- install SS break hoses install
- replace master cylinder
- replace rear brake line rounded one of the flare nuts trying to rebuild rear caliper
- replace radiator hoses/thermostat
- replace tires
- replace tie rod ends
- replace antifreeze/flush cooling system
- replace oil/filter
- replace radiator fan switch
Things to be done eventually:
- re-seal differintial (sp?) (gasket or just permatex?)
- install oil guard
- install working radio (IPOD capatible) got to have by LED ZEPPLIN
- install washer fluid resivoir
- replace timing belt/tensioner
- figure a way to rig a realase for trunk or replace trunk lock
- change trans oil and differitital oil
- research mods and apply if useful
Did I miss anything?
