engine swap
CrAzY RuSSian
engine swap
Post by CrAzY RuSSian »
i was wondering if i could put a 79 2L engine in a 78 car. if not what kiind of mods would i have to do?
bolts right in, but clearance between the hood and engine is tight since the 2L is a taller block. Best to also swap in the 2L crossmember at the same time.
It's a good way to pick up lots of torque
