Rocker Panel Removal
reservoirdog
Post by reservoirdog »
Trying to get off the rocker panels on my 82. I've removed all the screws, both top and bottom but it almost feels as if there is a weld on either end of the panel to the body. Or maybe they are rusted on.
Any advice out there on how to take these off?
Ira Brown
1982 Spider 2000
racydave
Post by racydave »
I used a die grinder with a cutting wheel. Remove exess weld, pry carefully apart.
Torxx
Post by Torxx »
I had the same issue. Turns out the screws in the each wheel well were covered by the orig. undercoating. Just had to scrape and dig to find the screw heads.
