Hi all,
I haven't noticed anyone showing any way to make your own bumberettes. So I figured I would show you one way you could. I know there is a lot of interest in getting cheap ones. I got some MDF and thought I would cut some shapes of what I want the bumperette to look like and glue them together. Then cover it with fiberglass to seal and protect them. I'm also giving it a thought of making a mold and making them out of rubber. But that's undecided.
First, you want to figure out what you want the bumpers to look like and where you want them on the car. I wanted a different shape than all of the other bumpers. Take a piece of cardboard and cut out the shape you came up with.
Here is what I came up with.
Now that you have the shape you desire. You have to figure out how wide you want the bumper to be. I figured to make mine wide and go with 6 pieces. I also decided to put the bumerettes underneath the inside corvette lights. I think I'm going to use the original bumper hole to install my reverse lights. These bumpers are pretty much just for looks. So I'm going to install them with a couple of studs. If I make them out of fiberglass, they will be pretty light.
Before I start cutting all the pieces needed to make one bumperette. You want to make sure of the angle of the area your putting them against is the same where it rests along the car no matter how wide you go. If it isn't, you will have to make several pieces of carboard shapes to make it fit nicely on the car. Mine was the same. No one wants a bumpers that doesn't lay nicely next to the car. So take your piece of cardboard and trace it on the MDF and cut it out. No matter what shape you want. Always cut at least 3/8" larger than needed. The back of the car isn't square. So your pieces won't be glued exactly next to each other. We will be sanding it down later.
Now take the first piece and set it along the car where the edge is going to sit. Use some tape as a reference. If the piece looks good and is perfectly cut, go back and cut the second shape. Make it 3/8" larger than the first. The only part that needs to exact is the back that lays next to the car.
As your making your pieces. Go back to the car and put them on to make sure they fit nicely.
Here is one I was messing with a while back. I cut a hole into it to see if I thought I wanted my reverse lights inside it. I didn't like it. This is the shape I'm going with though.
I will finish this post as I get it done within a few days. Hopes this helps someone.
Don't pay attention to the date on the pic's. Apparently it is wrong.
