I accidentally dislodged the clip on the cowl panel you see below. Photo 1 shows where it is missing, and photo 2 shows it in place. I was able to remove a few screws and reach in and get it. What does this clip hold in place? Is it necessary to rush to take off the panel to put it back in place? Thanks
-Sam
Fiat Club America Long Island Chapter Contact
1981 Fiat Spider 2000 (original owner)
1982 Fiat X1/9
2017 Alfa Romeo Giulia
2018 Alfa Stelvio
It helps hold the plastic cowl grill in place. One on each side along with the 3 rubber screws (for lack of a better term).
The cowl comes off pretty easy and if you removed enough screws to reach in and retrieve it, you probably had enough off to remove the cowl entirely and put the clip back in place.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
Ahh. I thought maybe it was for those plastic vents. Though the ones without the clips seem as stable as the ones with the clip. OK, THANKS, seems no rush to take the cowl off!
-Sam
1982 Fiat X1/9
2018 Alfa Stelvio
