My First Fiat - Parts car
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: My First Fiat - Parts car
Post by wachuko »
Europa wrote:
wachuko wrote: Now printing the workshop manual on clutch and transmission removal...
Which workshop manual do you have? If you need additional reference let me know.
pdf copy I found on the web... from here: http://www.corujoxx.com/MIWEB3/clubfiat/tecnica.htm
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
OK, I had to try... :)
And in case you ask, real men don't need hand lotion... :lol:
Drive Safe!
Wachuko
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
Transmission is out:
and, as everyone has suggested, you really need these..
Drive Safe!
Wachuko
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
The reason it was not shifting was that the actual shifter (skiing shaft or the dog) is frozen (red circled numbers). I took that top housing out (area in blue frame) and is now soaking in parts cleaner solution. Will continue to work on it tomorrow night.
Thank you Abey (Europa) for an excellent pdf on the tranny.
All for now. Good night.
Drive Safe!
Wachuko
2015 FIAT Abarth
azygoustoyou
Post by azygoustoyou »
What would make that part freeze up?
wachuko
Contact:
Post by wachuko »
azygoustoyou wrote:What would make that part freeze up?
Rust...
Before:
After (well, really more like work in progress):
Cleaned the part with just a wired brush. Was able to break loose the shaft. Took it out, cleaned it, removed the surface rust with a fine sand paper... I still need to get some parts cleaner to finish cleaning before finally putting it back together. Just put it back together for the photos.
But now it is loose and moving freely. I need to get me one of those nice soda blasting units...
Drive Safe!
Wachuko
2015 FIAT Abarth
red107
Contact:
Post by red107 »
With all that work might want to invest in a parts cleaner. Castro super clean works wonders on cleaning up greasy parts. Never used it for rusty ones.
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
wachuko
Contact:
Post by wachuko »
red107 wrote:With all that work might want to invest in a parts cleaner. Castro super clean works wonders on cleaning up greasy parts. Never used it for rusty ones.
Yes, that too... time to check on what specials Harbor Freight has on those.
On the media blasters, I saw an article on Grassroots Motorsports that mentioned one for around 200.00. I will look around to see what the price range is on those. Right now I need to control any expense as that will go against the budget for the car...
Drive Safe!
Wachuko
2015 FIAT Abarth
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
pope wrote:This kit would do it, but much more investigation has to be done to decide if it is even worth it. All the parts in the kit are what you would need to replace anyways.
http://www.classicricambi.com/index.php ... cts_id=413
Yikes!! I bought that same kit from Val for half the price! I haven't yet installed it, but Im glad I didn't wait to order it.
Trey
wachuko
Contact:
Post by wachuko »
Val??
Drive Safe!
Wachuko
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
Installing the shifter assembly back so I don't loose parts while cleaning the rest of the transmission...
looks like I will need to order the plastic piece... cracked on the bolt eyelets
Only question I have (can't remember :oops: ), the clip/spring in the shifter, what is the correct position?? :?:
Photo 1 or Photo 2? or different from the photos?
Photo 1:
Photo 2:
Drive Safe!
Wachuko
2015 FIAT Abarth
pope
Post by pope »
Photo 1 is correct. Make sure you grease those parts when you do final install.
Val sold his business. These are the new prices.
engineerted
Your car is a: 1974 124 spider
Post by engineerted »
So whats the clip for? I don't recall this clip on either of my two transmissions.
Ted
Ted
wachuko
Contact:
Post by wachuko »
engineerted wrote:So whats the clip for? I don't recall this clip on either of my two transmissions.
Ted
If the correct position is photo 1, I have the same question... I don't get the need for that clip :?:
Drive Safe!
Wachuko
2015 FIAT Abarth
pope
Post by pope »
It is a spring that pushes against the little metal alignment nub. It helps keep it pushed to the other side so that the plastic round globe doesnt tear into the edges there.
