Here's after - paint removed from radiator and polished the brass
Engine Bay Gallery! Please add your own!
Re: Engine Bay Gallery! Please add your own!
Here's the before the car was painted -
- maytag
showing off them carbs huhmaytag wrote:
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
where did u get the small stack and mesh for themmaytag wrote:
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
maytag wrote:
What kind of paint is that? Also, hiw much work went into polishing those hold downs (knobs) head etc. Other than polishing what else did you have to do? (or are these so shiney because theyre new?
Prepare to have your style copied albeit with a single carb instead of dual, and no awesome header
- maytag
the cam towers and the cam covers are "Wrinkle Paint" from VHT. It creates a very unique finish, and I really like it on my 'other' car.
note I used it on the water-neck and 'T' as well.
the head was "hot-tanked" or whatever the equivalent method is with aluminum parts at my machinist's shop, when it went in for the big-valves. Then when I got it home, I wiped it with a grease / tar remover, masked it, heated it, sprayed a thin coat of VHT "Engine Clear", allowed to flash, heated again & sprayed again, repeated 4 times. I've never used this method before, but it should allow easy cleaning of the parts without changing from the look of bare aluminum. (The heat/ spray process is one I've used for decades on motors. I once had the theory explained to me, and I said "BS".... but tried it.... and I've been sold ever since. But I never repeat the theory, 'cuz everybody else would say "BS" as well.
) NO POLISHING anywhere on this motor. Even the alternator was about CLEANING thoroughly, and then protecting that finish.
The nuts holding-down the valve-covers: shhhh.... be very quiet.... they're hi-temp aluminum header-wrap coating that I've had on the shelf forever. Incredibly durable.
As with ANY paint: prep is vital. A very, very thorough cleaning, and then a very-thorough cleaning-off of whatever you cleaned it with. MEK is great for a final clean on most parts, but a good wax/tar/grease remover can be pretty effective as well. DONT use anything with petroleum, alcohol, etc. for the final cleaning. your paint will peel in a heart-beat.
Well it looks amazing so screw what people say. Your theory obviously holds water.
That wrinkle red looks exactly like what on the old testarrosas
Thanks for the info, ill get started on even more cleaning tomorrow
quote="OffThaHorse"]That wrinkle red looks exactly like what on the old testarrosas[/quote]
Well there you go, guess what his other car is
Engine does look impressive
[maytag wrote:It creates a very unique finish, and I really like it on my 'other' car.
- maytag
thanks guys. Still a work in process. I moved the coil inside, but I still don;t like how busy that distributor and wires makes the motor. I need Mark's "distributorless" unit.
I've also got the early-style water-neck / thermostat I'll be swapping to. I'll do that when I pull the head. (I have to pull the head due to an unforseeable issue with the MLS head-gasket, so I'm going to wait 'til the exhaust system is built, then I can wrap the header while I'm at it too)
And then I think I'm done in the engine-bay.
But because I had to go and buy a LandRover for my newest driver in the family.... it seems I may never get to work on any other car ever again... that damn thing is either cursed, or they're just big piles -O- $h!t!
so while I'm dickin' around with it, the Spider and the TR are both just sitting.... waiting... haven't touched either in over a MONTH!
[quote="maytag"] that damn thing is either cursed, or they're just big piles -O- $h!t!
Sorry to hear that. Here they do not have a good reputation. The old ones are 10,000 parts loosely assembled around an oil leak, but they were relatively straight forward to repair.
The Japanese and German SUV's are the big sellers here.
- maytag
Same here. We actually have one of each!narfire wrote: The Japanese and German SUV's are the big sellers here.
My wife has an Isuzu SUV and I've got a Mercedes SUV....
This is not my first Rover..... but the RRC was a little less prone to EVERY LITTLE THING being broken, or ready to break. add to that my neighbor backing into it (and not telling me
I'm ready to write-it off
Not the first person to write their neighbours offmaytag wrote:I'm ready to write-it off
Makes me wonder how the British military cope if these vehicles are prone to a bunch of time on the hoist.
The Canuck military went with Mercedes. Saw one at Tim Hortons (similar to crispy cream I think) Big impressive vehicle.
Can you post a pic of the engine bay?
Jim
Jim
- maytag
Sunnuva....Jimb wrote:Can you post a pic of the engine bay?![]()
Jim
Point taken.
I'll stop hijacking the best thread on the site (other than the "Pretty Girls" thread, of course
Cheers...just intended for a laugh.
Jim
Jim
