Engine Swap Questions and Progress (was "Rebirth!")
- ga.spyder
Re: Engine Swap Questions and Progress (was "Rebirth!")
You know...I have never seen a picture of Ron where he wasnt sitting at someone elses table eating
Craig
Craig
Craig Nelson
Fling It Around Turns !
sorry, guys, i got up at 6.30 am to load up and go. but all i ended up doing was blowing chunks and laying in bed all day. wish i was there. i always seem to miss the good stuff. nice job.
- fiasco
- Your car is a: 1969 Fiat Spider
That's no good. We missed having you there, but I am very thankful for your help over the course of last week. Hope you get to feeling better, and I'm sure I'll talk to you again this coming week.spiderrey wrote:sorry, guys, i got up at 6.30 am to load up and go. but all i ended up doing was blowing chunks and laying in bed all day. wish i was there. i always seem to miss the good stuff. nice job.
-- se
Steve Eubanks
- fiasco
Got a LOT done, but still quite a bit left. The different configurations of the two engines threw us for a loop a couple of times. We went back and forth on whether to put it in the old configuration with the smog pump on the cam pulley, or to the new configuration with having to move the alternator wiring. Somehow we ended up with the cam towers for the new configuration and the pulleys for the old configuration, so there is a little backtracking to do there.So Cal Mark wrote:sorry I didn't make it back, what's left to do?
The various 'accessories' all still need to go on - alternator, oil filter thingy, smog pump, egr stuff... The oil procedure that Alvon described above, the engine needs to go into the car, and hook everything back up.
We never got to the point of rolling the car out of the garage to really clean out the engine bay, so I still need to do that before the engine goes back in.
My biggest concern is not things I know I need to do, but don't know how - I can always ask about those. It is all those things that I don't even know to ask. There were a lot of those yesterday - like Engine Assembly Lube. Never heard of it before, and didn't know it needed to go on the cam shafts when they were installed. If Alvon hadn't posted about the oil procedure, it would not have occurred to me to do it. My fear is how many of those kinds of things experienced wrenchers have in their heads that I'm just going to miss - so if you think of any, please just post them here and I'll use this as a sort of encyclopedia along with my manuals.
I'm taking the day off today. My family needs to be reminded that I don't live in the garage.
Thank again everyone!
-- se
Steve Eubanks
- Tappy
take some pics from the engine and bay from ervery angle before you place it pls
"You know...I have never seen a picture of Ron where he wasnt sitting at someone elses table eating
Craig"
Hey Craig, at my age I've learned when to volunteer. Plus, I try to look a little gaunt for the pity factor!
Ron
Craig"
Ron
o k, whats going on with the car now? its wensday and i havent seen any up dates?///////
Good question Rey. Ace and I were just talking, wondering how it's going.
Steve, how are you doing? Let us know if you need help.
Ron
Ron
- fiasco
My apologies! I've been swamped catching up on things that I let slide last week as I took every afternoon off to work on the car. I finally got back in the garage last night and just started putting things on the engine so that it would seem like I was making progress. Cyclonic trap, alternator, intake and exhaust manifolds are all on now, and I started switching back to the correct pulleys for the setup that takes the smog pump off the cam pulley. One of those pulleys has a really big nut which I can't get off, so Reyy, at some point I'll probably call to see if you can come over with your air wrench and bigger sockets again.
I still need to clean out the engine bay, circulate oil through the engine (per Alvon's instructions), and install more pieces and parts. I'm gonna have to remove two of the cam bolts on the intake side because they have to hold down the oil dipstick bracket, and we forgot to put that on - so that means two careful rounds of torquing those bolts again.
Tappy, I'll get some pics up for you as soon as I can.
Alvon - I got your voicemail late last night. We put three shims in, one was .1695, one was .1450 and the other went in before you asked me to start keeping track, so I don't have it. It should be in the neighborhood of .1455.
Thanks again!
-- se
Thanks again!
-- se
Steve Eubanks
Thanks Steve, hearing from you is a relief of sorts. I figured you were swamped, so I let you have some catch up time before giving a shout.
Keep us posted when you get a chance, and don't be shy about calling for help if you need it.
Ron
Ron
- Europa
- Your car is a: 1983 Pininfarina Spidereuropa
Steve, Can you (or anyone else) please explain the procedure for circulating oil through the engine after a fresh rebuild?seubanks wrote: I still need to clean out the engine bay, circulate oil through the engine (per Alvon's instructions), and install more pieces and parts.-- se
1983 Spidereuropa
Verde Scuro
Verde Scuro
Follow this thread back to an input by ventura ace on March 1, 7:42 AM. Any questions give me a call. 805-338-1767Europa wrote:
A
looks like theres no work for friday, should be able to get it handled then.
- Europa
Thank you Alvon. Somehow I missed your post. Wouldn't the aux shaft hit the crank, if the crank and the aux shaft doesn't rotate in unison?
1983 Spidereuropa
Verde Scuro
Verde Scuro
you cant hurt it turning it by your hand to see if its clear first.
